Was going to say earlier, but was on my phone so would have been too much effort.  Depending on the type of s/charger used will affect the power curve dramatically, and one more top end heavy than the other, but both will have more mid range than the other.
Turbo - Relies on exhaust gasses to produce boost and and even in a low boost setup, the benefits of being "turbo'd" will only come in higher up the rev range.  This type of charger will produce the most top end power but lowest mid range power.
Positive Displacement Superchargers - Produce an almost fixed level of boost and so will have relatively more mid range power than both a turbo and Centrifugal Supercharger.  This type of supercharger produces the most mid range, but lowest top end power.
Centrifugal Superchargers - Boost climbs with RPM but boost is instantaneuous and is available throughout the rev range.  This type of supercharger will produce a less mid range power than a positive displacement supercharger, but more top end power.  It will produce less top end power than a turbo but more mid range.
These are all horrible generalisations, but make the point.  Also hope I remembered the supercharger types correctly
