LiamP
Ignoring the fuel tank day disaster I am still enjoying this, it’s certainly testing me and life is getting in the way but have plenty of ‘unfinished projects’
#1 steering wheel control panel, been wanting to do this for a while, designed on fusion 360 and going to do it properly with race spec components. TrackFormula for the matt CF and blink stop for the buttons / stickers. Still need to finish reverse engineering the stalk, about half way there.
#2 centre panel, don’t trust the Renault dash anymore so moving everything closer and together near the gear stick.
#3 dashboard, my old one fits but it’s heavy and awkward where the clocks sit, looking at potential different options for this.
#4 loom, I have had more issues than expected with this as quite a few connectors had broken in the crash, ABS, brake, lights etc. Luckily I got a spare with the new shell but it is slightly different due to it being keyless, I am very close to just ripping it all out and building fresh..
#5 rain light, isn’t wired in yet but happy with this position, I didn’t want it inside the car as I found it to be a real pain in the saxo for visibility especially when lit. Installing in the bumper also means it’s super easy to wire using the fog light.
#6 OCD, started replacing various bolts in the windows and aerocatches, black is 10x better. Also removed all the silver foil from he inside, purchased some circular stickers instead.
#7 fire extinguisher, this arrived the day after I crashed, finally picked it up and thought I would get it installed whilst nothing is in the way. FEV Ali system, impressed with the weight and fixtures, installed as centrally as possible but need to finish the nozzles.
#8 pump, ported the oil pump to improve pressure at all revs, this will be interesting to see how it affects pressure / compares to those that shim the PRV.
#9 Piston balancing, got each to within 1g (piston + rod) now all rebuilt and ready for rings once gapped. 5-7am seems to be the only quiet time I get for this, really enjoying the process.
#10 Fixing and cleaning various parts which I keep finding broken.
#11 Rear beam, after some moving around everything seems much straighter. I am starting to think that I may have bolted it up wrong earlier this year introducing some rear toe out on the right which likely resulted in the crash :facepalm:
#12 Engine build, started planning this out, parts should be ready from AMS next week.
Old shell is getting collected on Tuesday and have done a big clear out in anticipation of getting chucked out at the end of next month. Found another unit which is 10mins away and no restriction on access which will be a massive help, also space for a trailer…
