I am hoping that we have now diagnosed our gearbox issues from early 2025 and have now got a solid gearbox. The morale of the story that I am going to tell you is that whenever you do any work on your Clio gearbox that involves some element of refurbishing or servicing always, always, always replace your slave cylinder.
In 2022 we had the gearbox refurbished with new 3rd and 4th synchros when we had a Gripper installed. At that time we had a new slave fitted. All this work was done by AW Motorworks.
It was early 2025 when our box started to crunch on gear changes. We thought it was the obvious issue of worn synchros as the crunchy gears were upshifts and downshifts in 3rd and 4th. The Gripper also needed a service. We had the box properly serviced by AW Motorworks again with new 3rd and 4th sychros, output shaft bearings and driveshaft seals. We ignored Alex's advice when he said that we should replace the slave and did not replace the slave as it had been replaced in 2022. That was a big and very expensive mistake.
We now know that the slave that was failing and that had caused the crunching in early 2025. As we did not replace the slave the box was just eating itself. Roll on to March 2025 when the slave completely failed to Mallory Park. We replaced the slave which hid problems until a track day at Snetterton in June when the crunching came back.
Ethan then rebuilt the gearbox in the shed replacing the 3rd/4th gear sliding hub, and the 5th/6th gear sliding hub and lots of other expensive parts just in time for us to get the Clio to the Nurburgring. The box seemed okay on the trip and managed to do about 1,200 miles including about 35 hard laps of the Nurburgring on some TF laps and a track day. These expensive new parts were now hiding the fact that the 3rd and 4th gears were getting damaged and that new synchros helped, but only hid the underlying problem.
At the Clio’s last track day of 2025 at Donington Park the gearbox gave up and became extremely difficult to change gear under load, particularly in 3rd and 4th. The car was parked up in November and not touched until recently.
I collected the gearbox from AW Motorworks earlier this week. The gearbox has been given a new 3rd/4th gear selector hub, new 3rd and 4th synchros, new input shaft seals, and new driveshaft seals. The 3rd and 4th gears have also been replaced. 4th Gear was only a good used gear as a new one was not available from Renault and may now be NLA. The tear down showed that where the slave had started to fail, and did fail, it had caused damage to 3rd and 4th gears. The replacement parts in June had masked the problem but had done nothing to stop the engagement teeth being chewed up and the gears themselves being damaged.
An OEM slave cylinder costs about £120. Had we replaced the slave in early 2025 we probably could have saved ourselves about £2,000, possibly more. We have put in a new OEM slave for the freshly refurbished box.
The gearbox has now been bolted back on to the Clio but there is still some work to do to get the Clio off the axle stands and back on to it's wheels for a test drive.
We have another 2 quarts of Redline transmission fluid to fill up the box. Our plan is to change the gearbox oil regularly rather than wait for any more issues before changing the fluid.
I am looking forward to using the Clio again. The first track day for the fresh box will be a 2 day event at Zandvoort so we will soon find out if 2025 was a bad year for the box which we can forget about in 2026.
