It’s nearly the end of the year and it has been quite eventful for the Clio. This year has been good fun with the usual smattering of track days, upgrades, and generally getting over the crash that meant the car had to be reshelled. Cadwell Park was a great track, Thurxton was a bit meh, Brands Hatch was good fun driving the Clio and the GR Yaris back to back, Oulton Park was good to meet up with others albeit it was a bit wet.
The back end of the car is now complete with a strengthened rear beam, spherical beam bearings, and a Cup spoiler. Aside from the usual maintenance of replacing the brake pads and discs I cannot think of any real improvements that we can make to the rear of the car at the moment.
Upgrades for 2024 will focus on the front end of the car as we intend to go stiff and spherical.
The six balljoints on the car are only a few years old but as we have spare arms and spare hubs we will do them again. The arms are with AW Motorworks now to have spherical bearings put in the arms and new ball joints. The subframe is also with Alex to be power coated and have solid PMS subframe bushes put in. We should get those parts back in mid January 2024.
We are going to order the parts for a Cup racer front end in February 2024 which will hopefully improve the handling with the roll centre correction effect. That handling of the car is pretty good at the moment so if it can be improved anymore then I can’t wait to drive it. I suspect that once we get the Cup racer front end on the Oz track wheels that we use may not fit anymore as the offset may be too low. At the moment the negative camber prevents most of the rubbing on the wheel arches and the edge of the front bumper. The car normally sits on a set of Speedlines that have road/wet tyres on and we have a spare set of Speedlines (both sets are 7.5J wheels) that we can use as track wheels if the Cup racer front end means we cannot use the Ozs anymore.
When the Cup racer front end has been done can then take a spare set of front hubs and put in them some uprated ball joints and new wheel bearings. Hopefully we can get the hubs done by April or May 2024.
That will leave a few bits to finish off like a PMS solid engine mount kit to really stiffen things up in time for a long drive to the Nurburgring in July 2024. The car will probably need some new brake pads before the summer trip.
After the Nurburgring trip we might swap out the Clio Brembo callipers at the front and replace them with a set of Megane 3 Brembo callipers. Ethan has now replaced the callipers on his Megane so we have a spare set available that would need to be refurbished by MS Custom Engineering as they look a bit tatty. This would also involve getting new brake pads and discs so could be reasonably expensive.
In addition to the bigger projects we will continue tinkering with the CANchecked device. We have ordered an oil pressure sensor, an oil temperature sensor and a sandwich plate so that we can monitor and log the data. We have decided not to get an oil cooler at this stage, but if we notice on hot track days the oil temperature is getting too hot we can always revisit that decision.
I thought that we would have removed the bulk of the interior of the car this year, but it is still there and there is no rush to remove it if we are driving across Europe in the car in the summer.
We have already booked a few track days for next year:
- Snetteron on 17th February 2024 with MSV
- Donington Park on 6th March 2024 with Track Obsession
- Cadwell Park on 22nd May 2024 with Track Obsession
- Nurburgring on 1st July 2024 with Circuit Days
I am looking forward to 2024 with the Clio and it's continued development in to a proper track car.
