My
my misses said that last nightlook a bit tiny to my liking..will they be up for the job??
Keep an eye on eBay. I got absolute bargain but was a fluke.lolWait and shop around, was someone on fuckbook selling everything
Have you got an engine?I'm confused now with the intercooler. I was planning on the normal sized R26 jobbies. Those others are tiddlers, but I see your point re blocking the rad.
Then you need cambelt kit and solid flywheel and clutch first.lolI've agreed to buy one yes
Do your research via rads and intercoolers mate! Well not just them lol...
See a lot of people end up buying twice or more when it comes to these conversions.
Lucky you have a guru helping you along in @Sean197
I'm all seriousness: I'm going to be the last n/a car on the entire forum soon....
So, in a break from thinking about the less important things in life, such as engine swaps, I decided to fit the Shuv creation mk2, aka the alarm bracket in stainless steel. I had recalled the original perhaps having a touch of surface corrosion, in the end it was rusted to buggery.
Doesn't fill me with confidence for the rest of the car...
And after fitting the new bracket.
Great job Shuv, keep those ideas coming!![]()
You're more indecisive than a room full of womenLatest update and just to further confuse you all, I've decided not to buy the 40k mile R26 engine.
I have decided to buy a Meg 250 engine with 28k on it, complete with turbo etc. Still need to buy the gearbox...
With the stronger internals, aim now is 310 bhp![]()
I used to be decisive but I'm not so sure nowYou're more indecisive than a room full of women
Thanks Sean. Yes the Walbro looks a good option. Don't fancy creating an engine bay overspill area in my bootStandard 250 internals are good for 360lb/ft, standard Clio fuel pump however is on the limit at 310bhp, and even then that's with 630cc injectors running a decent duty to compensate for the pump - Clio pump runs at 3bar, Megane one I believe is 5bar in the tank and 3bar at the rail. Ideally what you want is to have an uprated pump working a bit harder and to turn down the injector duty cycle, and plumb in a return system. Something like the Walboro 255 which is an in-tank pump is good, and I believe what RS Tuning use. You could of course run a second pump in-line with a swirl pot, but these are boot-mounted and are pretty loud.
