Hi , i drove the 197 a bit faster than i should and after i slowed down and start driving with like 50km/h , couple of km later the car just stall .... all sort of warning lights came on : Brake fault , ABS fault , ESP fault , Second air bag fault , etc . When i turn the contact on the engine fan start working and the steering wheel servo , the temp gauge is not moving , all other duals start ticking , and there is no starting the motor .... not even a click ....
I tried to reboot the comp by unplugging the battery , push the car a bit to jump start it .... the battery finally died.
What i am thinking is that the servo only work when the electric generator is working ... which is when the engine is working .... so the car thinks that it is working .... also the engine fan is working like 1 hour later when i towed the car back home .....
I have interface to connect it but the battery is dead now and charging ..... any ideas what to look for ?
Checked the oil .... it is there , i always drive maxed out . The coolant was not overheated , all belts are there ... no holes in the engine block .... the car was running fine .....
