Yiannis197
the gearbox on the 197 is the down fall...
You say it's a down fall but as far as I'm aware the 200 gearbox is slightly revised isn't it? Like, longer 6th (which is good) and slightly shorter 1,2,3? I wouldn't say that it's radically different. You can't even tell the shorter 3 gears in real life. The new 200 gearbox still fails (I read the other day that renault run out of gearboxes lol) same problems as the 197 one and you still can not engage 1st gear when it's cold. So how can it be miles apart?
driven a 200 and i could feel the better pull from the engine the quicker steering and cup chassis.....:thumbup:
I'm sure there is someone in here who replaced the ARB and rack of his 197 with the 200 (cup). He clearly said that it was his worse mod because he couldn't tell any differences whatsoever. I was about to do the same but I after reading his review I bottled it:huh:
this can go forever, 200 is better full stop. 197-200 miles apart?? no way
