ForgedV
Gold Member
Firstly I apologies for another thread about projectors.
I've been scanning through multiple threads and members posts on the conversion, and in the "how to" section but can't seem to find a thread that shows everything start to finish on how to do the conversion. So my question is does one exist?
I can see the front bumper removal thread but nothing that follows with doing the headlamp conversion. Also with the majority of people carrying out the conversion to fit Xenon HID kits, what kid they used and what bulbs etc, iirc its H1 dipped beam? Do the HID kits still allow for the bulb to sit into the headlamp correctly with only the spring clip holding it in place?
Also what people have done with the plugs? I'm not 100% sure on this one myself but i remember reading the plugs different? 3 pin to 2 pin for the headlight adjusters? How have people overcome this?
H7 bulbs for the corner bulbs which don't work I've seen that enough. Just looking to get all things ready to allow the conversion to go as smooth as possible.
Hopefully someone can point me in the right direction or answer the above questions.
Thank you
Conversion will be carried out using the ECP Valeo headlamps if that should make any difference rather than second hand.
Thank you
