Denners15
Gold Member
Hi all,
since I’ve owned my 197 I have a strange noise which sounds like an in sync judder when the car is running, the noise is coming from the left side of the engine and I’ve had full cambelt changed and clutch etc. Can only be heard at low revs.
Could this be the harmonic damper perishing causing more vibrations through the engine? Or possibly even AC pulley/Alternator. Wondering if anyone else has had a similar issue or noise. Did a quick run with the aux belt of and noise was slightly reduced.
I know without hearing it, it would be hard to determine but just want to know if anyone has experienced issues with their pulley. Renault recommend you change this during belt changes but that wasn’t common knowledge to me at the time.
Alex
Alex
