Crankshaft Position System Variation not learned
Untitled.jpg Well the problem is obvious but before you tell me to change my sensor it's a brand new one from renault sport is it possible the problem to be because I'm using lightweight flywheel and Helix 7.25 inch clutch kit ?
Yes and the car is running fine,but when I clean the error the check lite goes off and after 1-2 kilometers comes back on and it's the same error and I forgot to mention that I'm using Clio R3 pistons with bearings and conrods
