So i finally got around to installing the head unit I purchased a while ago as I had a bit of free time.
I had got all the connectors needed to make this a simple plug and play install and still retain the factory steering wheel controls.
The items are form Aerpro if anyone wanted to get them also.
I had watched a few videos on the internet on how to remove the standard head unit, and easily enough put some BBQ skewers in all four holes, push outwards on both sides and it slides out easily enough.
The hard part was disconnecting the plugs at the back which were really stuck in place.
all ready to go back in and also this head unit has microphone for phone calls, (not that anyone calls me........ so lonely........
I routed it to run up the steering column and drilled a hole into the surround and double sided taped it into place. Seems to work well
After this, I thought everything would be a super easy install...............IT WASN'T
Trying to push the head unit back into place with all those new cables behind it, was something that i could not explain the difficulty of. It just would not go back all the way in.
After maybe 25 mins of swearing i got it super close and then BAM it clicked into place. Hooray!!!!! Then realised the plastic surround needed to go on before pushing it into place....BOoooooooooo
Out it came and the struggle continued on for another hour or so. I finally got it into place again, and downloaded the sony app which is pretty useless if i must be honest. But you can change colors of the stereo through it, so YAY??
This is when the new drama started. The steering wheel controls worked, but they were weird and i wanted to manually program them myself which the head unit can do. Except it couldn't and i was stuck not really being able to swap between sources, and one button turned to unit off completely. So annoying.
After asking Sony Australia, Xplod, Sony UK, and getting shit all support or any info besides making a warranty claim, which was stupid because it was not broken, just did stoopit things.
I came across a post from the Uk Clio group 182 or something, and he had the same problem. He solved it by opening up the Connect2 box that allows the steering controls to work with aftermarket head units (Sony) and changed the dip set switch setting.
With zero support from Sony Australia i went on to try this and hoped it would solve the issue.
Glove box off this time, made life so much easier putting the head unit back in and shoving all the cables upwards, it was still a bit of a struggle but only took 5 mins after adjusting.
So with Sony and Pioneer head units, you will need to toggle dip set 4 down. This will allow it to work properly with Sony or Pioneer head units.
So it all when back together and shit me after a week, it was all working as it should. I was pretty happy with the result.
The sound has improved and the talk back radio stations are a lot more clearer for me to hear people complain about stuff. I should call the radio station and complain about Sony's fark all support. It was crap to say the least, and luckily i found the one post on the internet that had to answer to my problem.
Thanks for reading
Great Read
perhaps you can help me
doing exactly the same job with connects2
Sony head unit too
Not as lucky as you though as cant even get to work at all with steering wheel controls
am i doing something wrong that you can see maybe
took video but cant seem to upload
could possibly email to you
Using ISO connectors and supplied Patch lead jack into remote input on head unit
- 12 way molex from patch lead into connects2 interface
- Patch lead jack into head unit
- 14 way molex to connects2 interface
- connects2 interface iso’s and head unit mated
- connects2 interface iso’s and car mated
- No control
