CL10 CYA project
It won't go into reverse
It originally had a short shift kit on the box
Then the previous owner fitted the zero one
But was never setup
But stumped what to do - trying to find a standard selector
And radiator fan wiring
I am missing the radiator fan resistor
Can't seem to find one for a that I trust is for an RS, I have a jumper wire round it just now
Anyone shed some light??
I don't know the solution to the gear linkage issue but have you got a Clio box or a Megane box. The ZPOs are different depending on what box you have got. Terry at ZPO is good with communications so you could try contacting him?
It is good to see that your hard work is paying off and the car is now moving.
Reactions: Sean.R
So it's a Meg box
And this short shifter fitted
I will have a little play with it today before reaching out.
Can't imagine it will be easy finding a OEM selector
This will give you a giggle
Decided to email Terry at Zero one
Very helpful and on a Sunday evening
He mentioned about adjusting the gub screws etc and then the reverse gear on a Meglio is in a different position
So stupid question was asked - where is reverse
It's down and to the right of 6th
Straight out to rgr car this morning
And it now goes into reverse
I will happily take the easy fixes all day long
Few jobs done today but back to work tomorrow so on hold again
Reverse sorted
Boost controller rpm lead wired in
Fixed the headlights
Bumper on and started to sort the bonnet needs a trim on the inside for the coolant bottle lid
Changed the boost controller vac lines
