Most vans that price will be mate lolWas a pile of shite lol!!@
It will be one of your better purchases i promise bud.....
So have you got a garage you can store the car in too......or is this 'just' a mile-saver ?
Once the thought of not using your car in Winter/ to save miles is in your head; there's no going back. Van will be a lovely, useful tool too. I'm always borrowing from work. some of the small, modern TD's go like stink too.
Good luck !
Just a though Chris up here our you need appointments to use tips of you have a van as counted as commercial waste. My boss bought a Berlingo for this purpose as its a 'car'.
LMAO!
Eh? Thought you had pulled out?! Be good if you do make it.See you at SPA IN APRIL
Cheers guys - great points there.
My dads looking at an 06 estate focus 1.8 diesel atm. To be honest as long as its not huge, cheap to run, insure and is reliable, I'm not too fussed what it is, van, car, van-car.... He's leaning away from a proper van so we can bung the dogs in the back when they're all muddy etc. For me its just a means of keeping miles off the clio, and hopefully a bit cheaper for my work run.
I think the ethos is right. A long as its spacious - and therefore multi-purpose - to some degree it don't matter what it is. And at that sort of price-point; mileage, history, current owner etc and gut feeling is more important than the badge per-se.
Is you Dad car-proud ? You two aren't gonna fight over this once purchased are you![]()
That is a bloody liberty threatening to charge you for removing door card!Nothing exiting happened here, unless you count a new set of bosch wiper blades - woo!
Went in for its service at renault rawlinsons on friday, all hunky dory... Apparently gearbox oil is noted down as every 100k on these.
Ive noticed a small rust bubble above the drivers side door handle, which I pointed out to them. Get this, they need to take the door card out to see if there is corrosion on the inside of the door, if there is none visible inside the door, then apparently they want me to pay for the luxury of them taking my door card off £100 as it has to be all the way through for it to be done under warranty. I told them to get stuffed and id be contacting RUK about this.
F | Rear ABS sensor , difference between 200t trophy and non trophy ? | Suspension, Brakes & Steering | 0 | |
Liquid yellow 200t | Spotted | 0 | |
Gear problem Auto 200t | Clio 200T Area | 2 | |
L | Chris's UR 197 | Projects/Progress Threads | 11 | |
Chris's rs 200 cup :) | Projects/Progress Threads | 2 |
