FAO - @
tchalikias
I had a pulling issue start a few years back and got progressively worse on my 197.
I keep on top of the suspension components maintenance and have changed all the ball joints, I purchased new bottom arms as the ball joint was split. I've since added Powerflex bushes to the arms and anti-roll bar.
Top Mounts are also really common to go, and when fitting my KW V1's, you do not require a bearing any more.
Tyres - New Yoko tyres (AD08R) for a Nurburgring trip were also something I ruled out from my previous Hankook Evo v12's.
My 197 is on 90k mileage and I was aware of 'play' in my steering rack, the most recent replacement was a new steering rack, specifically the 200 Cup rack, as it was cheaper and fits the 197.
Had the car tracked, and it is now driving perfectly straight. The steering wheel used to fall away to the left, but that is no longer the case.
Depending on what you have replaced, I'd check for play in your steering rack.
Your clunking issue could well be the steering rack. Parked up when going lock to lock, I could hear it was obvious the rack had a problem.
Last time I checked Renault's pricing was approx:
197 Cup Rack - £399.80
200 Cup Rack - £279.19
197 Cup - Part Number: 8200822946
200 Cup - Part Number: 8200824576
Let me know if you need any more information.
Hope this helps.
James.
