Get the reyland/cazan, I saw you were going for ds2500's, those pads will overheat before you need to be concerned about the internal vein structure of the rotors.
Iirc is they are using AP bolt spacing so you can always replace the rotors with 330mm AP when the time comes. -That's my plan anyway, my 330's I'm hoping will turn up this week.
Thanks mate. So you've bought the Cazan kit then?
There are basically three options right?
Cazan 330mm
Performance Friction 330mm
AP 310??mm
The top two need a bracket to space the calipers out from the discs, and the Cazan ones are cheapest. That sound right? Tempted with the Cazan kit, if you are able to stick some photos up of yours when they arrive that would be cool [emoji106]
Cazan 330mm
AP 310??mm
No there's one more, I have Godspeed 330mm on my Megane now so there's another make to throw in the mix.
im really happy with them and using DS3000 pads with them.
Are yours two piece dude? Any pics?
Also have Brembo 313mm and Ktec (presume 312mm and hi spec I think they are) as 2-piece options.
My Cazan have turned up:
They have strange machine marks though which I'm checking on as I have never had discs with this on before:
The caliper spacers are just 4 x black steel circular pieces - not like the Performance firction which uses a machined piece of metal shaped like a bar.
Also the kit didn't come with longer caliper bolts whereas the Performance friction kit does. I am going to get a price for the bolts from Ktec - tbh at the moment I would just say get the PF kit.... I may send mine back. I just wanted gold bells against the LY paint
Yeah the grooves in the rotors are balance cuts and apparently normal. So thats cool.
Just the bolts to try and sort.
The spacer on the rallye is irrelevant because it converts from lug to radial mount iirc.
These spacers simply push out the caliper by X mm to allow for the bigger disc. I was expecting a bar but if you look at the hub design a bar offers no improvement to rigidity, so the collars (think fat washers) supplied in the Reyland kit are fine.
I have no issues with the kit except for the lack of longer bolts. Apparently Reyland tested the OE bolts and found them fine... I am probably being paranoid but I like to tackle everything I do with an element of over engineering!
Yea I know the design is different in the Rallye was just showing the quality of the AP set up its mint!
Ok so those Cazans shouldn't need long bolts then. Surely there will be less thread in contact if they can't bolt in as far? It may be fine but think I'd source some longer high tensiles from silverstone motor factors if I go for these.
The AP discs for the Clio just fit straight on under the oem calipers without spacers right? And the ketch kit (which I believe is made by PF) cone with longer bolts. If it's one area I wouldn't take the risk on its brakes! I do like things to be over engineered too so I hear where you're coming from dude!
Exactly, I've only got a crappy tape measure to hand but about 10mm less thread in the hole. (I think the Godspeed kit mentions 9mm longer bolts so makes sense, esp given the discs are 18mm bigger).
Reyland say it's not a problem to use OE, but I kinda feel it wouldn't hurt to source some 9mm longer HT bolts. IMO they should really be supplied.
AP discs fit straight on, but the discs are 2mm smaller. You could never possibly notice it, and the strucutre of the discs (curved internal veins) means it will perform very well. But knowing i'd fitted smaller discs would just bug the **** out of me!
Ktec do 2. They resale the PF kit (330mm), and they have an OE size kit - which I believe is actually made by Hi Spec.
The 'best', are the PF kits. However, I have seen PF kits with poorly weathered bells after not much use. Also black is too boring, so you'd have to factor in re-anodising costs of the bells if you want Gold - which I do.
The best after that would be Reyland kit but fitted with 330mm AP rotors. This is what I will do when the Reyland rotors (machined from Pagid blanks) wear out. The 330mm AP rotors are about £500, so too much to buy at the same time as the bells.
