New pads & discs, bleed brakes?
So I just bought DS2500 pads all round and Mtec grooved discs all round and I'm debating if I should get the brakes bled? I'll be fitting the pads and discs myself as I'll be fitting H&R springs. Is it worth getting the brakes bled? Not got a massive knowledge with to do with brake fade and heat build up and dissipation. It gets Rare track use but mostly fast road. Cheers!
Its worth it if its not been done. Not too hard to do yourself with an ezy bleed kit either.
Uprate the fluid for sure.
i put Motul RB660 in only because I'm going to the ring in April and my fluid boiled very quickly last year. No chance of that happening again this year. For say £20-£30 you can put fluid in that will be squeak free and boil free but slightly better in response.
