Update 02.05.2015
After fitting the front splitter to the Clio I decided something just didn't look right with how the car was sitting.
I started into the research looking at pictures of other 197s and at the start I saw an image on Instagram of a 197 sitting what I felt was perfectly, it had 15mm spacers on the front and 20mm on the rear. I did a bit of research via Clio197.net to see what everyone thought of this idea, only to be told that I really shouldn't stagger the spacers. I was told be a fellow forum member that the old cup race cars used to fit 5mm spacers up front to give extra track over the rear, so that really put me off the idea of staggering the rears more than the front anyway. The most common option seemed to be to run 20mm spacers all around with a select few option for the slightly wider 25mm. Again after some research I found that the downside of running 25mm is that your splatter your rear quarter with stones.
I was pricing spacers everywhere I could find them, from Gumtree to Renault tuners in France. In the end I stumbled across a set of second had 20mm spacers for sale on Clio197.net. The person selling the spacers had bought them, painted the edges black and then fitted them to the car, however before he even took the car out on the road, he decided he didn't like the look of the stance. I felt these were just what I was after as they were pretty much brand new.
A couple of days after the purchase they arrived, accompanied by some extended bolts...
Before
After
Fitting of the spacers probably took me the guts of an hour as it was a bit fiddly at times getting the holes lined up, but I got there in the end.
I'm sure you'll agree the car is sitting a lot better now. The only thing that now tempts me is, should I lower it?
You might remember a few weeks ago I treated myself, well the car to these...
Well I felt now I'd fitted the spacers and the cars really starting to take shape, that now was as good a time as any to fit them.
Before
After
As always, comments are welcome.
John
SaveSave
