tombate911
Ordered myself a new diff. Didn't last long not touching it after Snetterton.
Decided it was the end of the road for the quaife, it's been a great diff in the car which I've ran with a 3.38 and a 3.73 ratio. But I am finding the limit of it more and more with the car this past year.
Removed the old diff with the 3.73 ratio and decided to sell it as a complete built unit, already sold and gone to a new home! It didn't make sense to strip down a perfectly working diff to make the new one.
Bought another 3.38 ratio diff from an auto to use as a donor
Started with disassembly of the donor, can confirm old diff oil still stinks. Ripped it open on an old towel and thrown them straight in the bin
Obviously I couldn't leave the casing in the rusty old state so gave it a good jet wash, degrease and a wipe down with some thinners before giving it a coat of paint
Put all the parts through the parts washer and laid everything out ready for building.
https://live.staticflickr.com/65535/53841986548_55ee776f6c_z.jpg[img]
Bearings and crown wheel fitted to the diff, getting some more use out of the press I bought many years ago on a bit on a bit of a whim, turns out I use it all the time.
[img]https://live.staticflickr.com/65535/53840874557_2c79f8f89b_z.jpg
Started with setting up the bearings and the pinion drag and then set about putting the diff in the casing with the bearing on.
Got loads of photos but will keep the post short rather than a how to. In total about 6-7 hours worth of building, due to the size of the diff unit it doesn't fit inside the diff casing in one piece, so every time you want to take it out to adjust the shims you have to split the diff in two.
Managed to get the bearing clearance to a spec I was happy with as well as getting the backlash to 0.1mm. Overall everything has gone together with the provided shims which come with the Kaaz diff but it's right on the tight end of the spec
All reassembled with new seals. I have built this one with a 3.38 final drive and while the diff was apart to fit it inside the casing I have dropped the lock down to 65% as per the Kaaz Manual which they refer to as the "Medium Hard Setup"
Back in the car it goes
Bought a set of replacement discs for the rear while I was working on the rear end as well as a replacement ARB bracket, somehow managed to loose a bracket at Snetterton, I think I've forgot to torque the bolt up for the bracket when messing with fitting and removing the rear ARB and the bracket has left the chat
Final job for the weekend was adjusting the splitter mounts, with the new bumper the splitter needed raising 15mm to bring it up snug under the bumper, adjusted the brackets and refitted.
Note- That isn't the placement for the reg plate... Just popped it on there for today as I didn't want to mark the new bumper
Been a big job but it will hopefully be worth it, we'll see on the next track day!
