So with the wheels back from the powder coaters it was time to get them sealed and tyres mounted back on them so the car can come off the axle stands and back onto the ground
but before that could happen I still had a list of jobs to be getting on with. First was drain the gearbox fluid from the last track day, fit the M16x1.5 to 1/8th NPT adapter and fit the temp sensor to the gearbox and refill with the new Redline MT-90 fluid.
With the sensor fitted there is no way to read the signal/resistance of the sensor with the standard ECU, this would have been dead simple if i was running stand alone. I could have got a cheap sender and gauge but whats the fun in that.
Started mocking up a little circuit to read the temperature using a pull down resistor to make a potential divider and combine that with a Arduino with an LCD screen. Couple of hours doing the maths and writing the code from scratch.
Gearbox temp output on a little LCD screen. Now it's just time to neaten up the wiring and design and 3D print a little box for it to go in with the LCD screen visible.
Slight adjustment to the shims on the rear beam to bring the toe square rather than the excessive amounts of toe in I've been running since it was lowered.
While I was there I took the discs off, skimmed them slightly and ground all the rust off and repainted black.
Also lifted the rear of the car 10mm to give it a little more rake to help with the handling on track combined with the now parallel rear beam.
Once that was done it was time to finish off what I had started with the interior. With all the sound deadening removed and varies things like seatbelts and speakers removed from the rear I put back some of the interior to keep the car looking good, purely for the aesthetic reasons put some of the rear panels back in.
Before doing that spent a little bit of time on the wiring to make sure there was no airbag warning lights left on the dash with the seat belt pretensioners removed.
Gave it a wash while it was on axles stands and did all the brakes, coilovers and under the arches before refitting the wheels.
I'm sure there are so many things I've not written about on here that I've been messing with over the past couple of weeks.
