Cadwell Park 27th July 2017
Been a little while since I've posted on here or updated this thread since fitting the diff. Since then the only thing I have done is repainted the spoiler end caps, you can see for your self in the photos.
Well I've finished work for 6 weeks so perfect time to get a track day in mid week which I normally can't do.
Been wanting to do Cadwell Park since I got the car so it was a perfect opportunity to get it done and make the most of the summer weather!
I set about loading up the van and trailer Wednesday morning and set off on the 3 hoursdrive to Cadwell Park Wednesday afternoon. I drove straight to the circuit and found a good location to set up camp for the next two days. Got my self nice and close to the pit lane entry point as close as you can be to the circuit.
I spent the night camping at the circuit in my van so set the alarm for 7am, I had taken the car off the trailer the night before so was pretty much ready to go in the morning, just a quick change of tyres to the drys and ready to go.
Sighting laps out of the way and it's very clear to see what a good circuit it was going to be with a massive amount of elevation change which you really cannot appreciate on the video footage from the track until you've driven it.
Car was performing absolutely amazingly. Gripper diff making a massive difference getting the power down in the corners and helping the car hold the racing line though the corners. Also the FD on the gearbox really helped the Clio out on the straights able to really use 5th gear now and continue to accelerate. Shorter gears allowed me to always be in the correct rev range especially between 4th/5th
As the day went on and I got a little more familiar with the track I started to push on with the pace chasing down some much more high powered cars, very fast on the straights but very easily reigned in on a track like Cadwell.
Made some tweaks to the car throughout the day. Actually softened the front dampers a couple of clicks, Cadwell is a very bumpy track!
Removed the 20mm rear spacers from the back axles to see what change it had on the feel of the car, before doing it I would have said there would be no difference... However much better turn in and less understeer through some of the slower sharper corners such as the hairpin at the end of Hall Bends.
Only one mechanical issue on the day which was the alternator which decided it would stop charging the car after about 15 minutes in on the last two sessions and would only kick out about 12.5v. Let the car cool down and it was back to 14v for about 15 minutes on track. Going to swap it out for a spare I've got and have it rebuilt and tested.
Post track day fixing and care is underway now, first job as soon as the car came off the trailer was to get it on 4 axles stands for a few weeks so I can get some jobs sorted on it before it goes out on track again, here's a little list of things to come
Powder coat 2x sets of wheels
Shim the rear beam parallel
New gearbox oil
New gearbox cables
Temperature sensor and wiring fitted to the gearbox to research oil temperatures
Solid engine mounts being made
Check and give the brakes F/R a once over
Alternator swap
Some other smaller TLC and Maintenance on the the go.
