Winding back Rear Calliper Question
When winding back the rear callipers to change the brake pads do I pump the brake pedal after I have done one side or after I have wound back both callipers?
hand brake off, do both (imo) then pump brake and ratchet hand brake and test slowly before going out anywhere.
that's the sort of way I have always done it - you can then make sure both running clearance/resistance is the same side to side
