Will r26 discs fit my 200?
I like the drilled set up on the discs and I have found some for a good price. What I am asking will the fronts and rears fit my 200? Cheers
The rear discs are 1mm thicker but fit. you just have to be carefull on the rear bearings IIRC, two choices on the megane.
Aren't the R26R's drilled discs prone to cracking?
I've read of a few instances of this.
Whoa, never seen a disc failed like that before! Had heard of R26 discs cracking around drilled holes though.
Standard brembo discs are more than up to the task to be honest, just stick some good pads on them and do your cool down laps if tracking it. And, I say that having had a set of KTEC 2-piece discs which overheated at bedford.
Both those images of discs posted above appear to have the crack originating from where the grove meets the edge of the disc.
Seems like a good idea not to get grooved discs.
