I know the difference between perfohub/revoknuckle and McP, but its irrelevant in this case.Ah but this isn't a basic MacP setup, it has a steering knuckleso the kingpin inclination axis doesn't run through the top mount and wishbone bottom balljoint.
This is Ford 'revo' but exactly the same concept as Renault (and also Vauxhall HiPer):
You can still of course use top mounts on the main strut to gain camber, but the lower balljoint can ONLY increase camber if you lengthen it. Without lengthening it then it operates always on the same radius/arc. There is no 'maybe operating on the same' line.... if the subframe wishbone mount is in the same position, then with a wishbone of a fixed length it simply can not operate off the raidus line. Think of the wishbone subframe mount as fixed to the centre of a circle, and the EE balljoint will always stay a fixed amount away from the centre point no matter how it is rotated
I'm told you can't get more than about -3deg on the top mounts alone, and hence why the Cup Racer must have a longer secondary bearing position (EE bracket) to push the hub out and achieve around -4.5deg, and also this movement at this position will give a track width increase.
If you can try and measure the 'red' and 'green' distances on the previous image so we can work out the 'yellow' - that would be awesome :thumbup:
Consider two setups being the same in every aspect except lower hub to wishbone mounting point (in setup #2- on the right, mounting point is moved to the right compered to the setup #1). If wishbone have the same lenght in both cases and wishbone to subframe mounting point stays unchanged just as top mount position, DOES the wheel move further out with increased camber? YES or NO?
