Modified Akrapovic, who's done it?
Considering a res delete on the Akra just to give it a bit more edge. Has anyone done anything like this? Probably won't change out the manifold for now as it's such a big job... Such a shame the cat is in the manifold.
Show me what you've got!
I done it (Removed the resonator) and had to go back to the resonator equipped centre section after 2 weeks. On track it sounded properly awesome however it created a massive flatspot and the day to day drone was horrendous.
Thanks mate. Will probably end up leaving it in in that case. Cheers
Hi i am running Akrapovic with the resonated centre pipe.
I am wondering if it is beneficial to decat the manifold cat?
Any opinions?
Any opinions?
Well an Akrapovic with the resonator still and an R3 manifold (so decat) - trips the noise meters at Bedford, so I wouldn't advise any de-cat manifold with an Akra.
@NOddie
was it mapped when you deleted the centre section?
the baffle / baffles have gone in mine and needs to come out
Any difference in performance? I am expecting a stronger high end pull and a more responsive mid range torque.
Mine is tuned.
