Clio V6 Airbox is now only available as a special order from France unless you find a second hand one which is like finding hens teeth. Any decent Renault dealer will be able to order it for you but you might be waiting 4-6 weeks, same with the inlet-airbox pipe. You can get a tray too that sits on the original battery tray and helps to hold the new aibox in place securely, again, it's a special order jobbie. I think I have the part numbers saved on the laptop if you want them N0ddie? Although one of the numbers comes up as a ''bad number'' at my local dealer for some reason but World Of Parts could find it on their system.
