Track focused geo settings
I’m back at Donington on 19th May so I’ll have a play with tyre pressure thanks [emoji4]
Regarding coilovers / lowering does the 200 require adjustable droplinks or is this a nice to have? (thought I would ask on this thread as others might find it useful)
I just got some cheap pro sport ones off eBay. They were the longest ones which came out of the 3 choices
not really much useful info for ya. Sorry
Reactions: LiamP
A question for people with gaz golds. Is this normal that if i wanted more camber than this, I can’t tighten the bolts?
My friend drilled another hole in the centre of the silver parts in order to get more camber.
I’ve seen some people run only 2 pins:poke:
I had similar on my old E36, we had to set camber off visible bolts, then undo top mount bolts once we got the correct camber and put the other 2 bolts in. As mine had caster adjustment too you get used to doing it that way after a while lol.
Reactions: av4625
