RSRowe
Yeah basically the exact same I did with the scuttle panel.It’s a Weeder Motorsport plate. The holes could do with a bit of tweaking, and I also had to space it up with nuts as it doesn’t sit flat.
I extended 2 of the wires and then untaped the loom which runs by the chassis leg. Was pretty easy to do. Be sound for you given you’ve got all the tools.
Already cleared all that. Sawed the little tab off underneath and took a flap wheel to the plastic. Oh, and I cut the pipe down about 10mm on each end.
0.6mmWhat nozzle size did you go up to? There are so many variables on 3D printers, me and Adam Thomas have been talking about how "secret" options in Cura for example, a lot of trail and error to see what works for you!
Ha yeah, I always slice something the night before and set it going in morning, joys of WFH.
Also printed my first Cockosaurus and sent it to a friend (as I printed him some angled spacers for his camera doorbell)
Anyways we have made your Clio thread a 3D printer thread haha.
Good idea on cutting the hose down actually, I hadn't thought of that. May do the same as it's a mega tight fit in there.
May also look at doing the same with the fuse boxes. I just have mine cable tied up at the moment
Nice one. I did attempt at doing full cup racer settings but the tyres ended up scrubbing in the rear.I've got to say that sits absolutely perfectly![]()
| S | DS2500 part number for 197 fronts? | Suspension, Brakes & Steering | 1 | |
| J | Dipstick 197/200 | Clio General Chat | 1 | |
| S | Air Intakes for the 197 | Clio 197 Area | 0 | |
| O | Gear crunchy 2nd to 3rd around 3000rpm+ | Clio 200 Area | 9 |
