SWR STIRLING
AULDJOCKRACER
Gold Member
Haven't posted before in my 50's hence nickname.
and been a member for a few years including cliosport net when i had my 172 had them all since the renault 5 turbo and Clio Williams so do quite a lot of simpler work myself top end work just wont go down on her too old cant get back up and had a jack fail on me. I don't disagree with anyone thinking about getting any work done in Scotland should consider Rentec in Edinburgh if on your doorstep and yeh all decent guys I gave them a try when i was working in Edinburgh but i stay in Livingston slap bag between Rentec and SWR and i have been going to SWR over 10 yrs now no issues but have had hiccups with Rentec . Both have ex Renault technicians with years of experience under their belt. SWR those guys do all the work i get the feeling at Rentect the guys with the knowledge only instruct the workers as its a bigger concern . Had a gearbox fitted got as far as m8 and couldn't get a gear clutch not bled and gear links not popped on correctly to gearbox selector not a big issue but schoolboy error as experienced guy would fit gearbox and let young trainee button up and test drive? As i say no biggy but happened on m8 and had to stay in 3rd till i could pull off m8 and get Brian to meet me at mothers house as it was closest . Its been SWR every time for me only issue as they are good obviously busy if its a job you know you want doing phone early as bookings go quick. Just putting it out their more than 1 scottish renault specialist , Dealers don't count unless you want raped .
Reactions: Beany and DS197
N0ddie
Been using them since they opened back in 2010. Best garage for anything you need done to any car.
Sean197
RIP Albi :(
Moderator
Used SWR once, brilliant service and would definitely use them again.
Used Rentec in Edinburgh once, wouldn't let them oil the chain on my mountain bike.
Graham200
Gold Member
I wish all mechanics were as good as SWR. Been using them for a couple of years now. They sourced a fault that had plagued me for months.
They have a clio 197 and know the cars well. Last time I was up they had a track spec 911 on the ramps and have seen a few other tasty motors up there. It's an hour away from me, but I wouldn't take my clio anywhere else.
