UPDATE:
Every day i spend on this car the closer I get to that first drive
Today I have installed the passenger side hub and driveshaft, gave the driveshaft a good coat of hammerite again. This side has also had all the bearings replaced. The drop links though are the originals as they are in good condition. They are again painted in athracite to match the engine. I can now fill the gearbox with oil, Ill do this tomorrow and Im going to use Fuchs syntrax.
Most conversions I have seen use the 197 coolant tank and mount it behind the battery, I didnt like this as the air filter is completely blocked from the cold air. i have therefore purchased a 182 tank and Im going to mount it on the far left of the engine bay by the engine mounts. The tank needed a bit of filing to get it to fit but it now fits perfectly, Ill make up some brackets in the week to mount it more securely.
The mounting bracket that was supplied with the fuel pressure reg wasnt long enough to fit in my ideal position on the rocker cover, I therefore in the week constructed a bracket out of some aluminium. I have then polished it up to a miror, the pressure reg now sits nicely and almost looks like its meant to be there :lol: Ill plumb this up before mapping when I install my bosch 044 pump.
Tomorrow I hope to start the engine for the first time
Ive got to install the callipers and bleed them, fill the gearbox with oil, finish the coolant system and fill with coolant, prime the engine with oil, install the brake discs, put the wheels back on and then I should be able to start it and get it out of the garage ready for installing the rear springs and finalising the exhaust system.
