197JST
Gold Member
Greetings every one,
Ive recently been notified of the ABS / ESP sensor error on the dash warning.
Is this a job that can be easily worked, when I was cleaning the wheel arches earlier in the year, I noticed some corrosion around the back of the rear disks, this is where the ABS ring is located, since the warning appearing on the dash this is were Im thinking to start to fix the problem.
Is this some thing that can be replaced quiet easily?
