richandgem
Quick Q Rich - are they just standard discs that you are able to machine then? No possible issues with failure along the grooves?
Dont rub down the paint too get a Key mate its a waste of time and effort !
Get some Nitromors paint stripper, a 50p brush & medium grade steel wool.
If you've never used nitromors before don't brush it on 'stipple' it on it works much better
It'll give you a much better finish, wet sand (320 grit) the primer your using then put the finish on. Wet sand any other rough part in-between coats but not the full thing as theres no need.
Have a look at mine,
http://clio197.net/forum/showthread.php?t=2261
tempting me to get a cage now....
S | Upgrade projectors to HID | Clio General Chat | 6 | |
Kiwi Clio project | New Members | 10 | |
S | CL10 CYA project | Projects/Progress Threads | 193 | |
My 197 - Project / Track Car | Projects/Progress Threads | 3 | |
Silver project camber tops | Suspension, Brakes & Steering | 4 |
