Fernandez
Gold Member
a slight buzz through the pedals and the mirror shakes slightly
Because Racecar...:driveby:
[MENTION=58]Raptor6767[/MENTION] Powerflex don't do one for the Clio but they do do a universal 22mm bush..Is there a possibility of a 22mm (Clio Cup Racer) ARB bushes?
TNX for the info.
Haven't fitted the ones for the engine. Still in Rome...![]()
The black ones are much tougher and designed for race use. The vibrations will be very strong and on anything other than a smooth circuit they will be killers.
Initially I intended to purchase set of standard Powerflex bushes for engine (becouse of vibrations) and set of black series bushes for the front arms and rear beam (in order to get the best handling response), but maybe it will be better to order standard Powerflex bushes for whole car, if you think the black series is to firm for everyday driving and occasional tracking. Actually, I have standard cup suspension, but I am going to switch to KW V3/Clusport or similar level coilovers soon.
What happened to the Group Buy thread?
@Fernandez
The rear ones (with anti lift and caster adjustments) give more 6 degrees of caster or up to 6degrees?
For example, on the alignment sheet my car got 5°04' (left wheel) and 5°48' (right wheel) of caster but the factory values are between 4°59' and 6°17'.
Tanks for the reply
So it's up to 6°... Changing the oem and put the powerflex ones on maximun option (like instrutions) should be around 6°.
Got all 3 engine mounts and just had front arm bushes done, quite a difference before/after....+ front upper strut and rear ARB....car now corners flat and noticed Very little lift on acceleration!! All thanks to Angel/cazan for supplying.....definitely recommend!!
Used Powerflex Rear Beam Bushes | Car Parts For Sale | 1 | |
Powerflex Bushes | Clio 197 Area | 3 | |
Powerflex lower arm bushes.. | Suspension, Brakes & Steering | 7 | |
Sold: Powerflex bushes | Car Parts For Sale | 4 | |
J | Powerflex bushes - top engine mount and dogbone mount inserts | eBay Finds | 3 |
