I am indeed, if you have a passenger seat I'll hop in for a lap or two.Are you at Snetterton on the 19th? If so, you can have a go
Matt is fitting the passenger seat at Snetterton so all good!I am indeed, if you have a passenger seat I'll hop in for a lap or two.
I think that if the right offer comes in then I’ll let her go. I’ve got Donington on the 7th, I’ll see how that goes and go from there.I saw your post on Facebook - are you really selling up before you enjoy the unique Clio that you have created?
. Proper man logic, spend more money on the money pit.Yeah, hopefully it’s not prohibitively loud for some tracks. It’s just had its MOT so I’m good for 12 months and then I’ll likely just trailer it to tracks. Unfortunately I’ll have to cut the Akra down as the PMS manifold is longer than the OE one.That is one way to deal with a broken flexi.
Are you going full decat with the Akra?
From what I can see they look good, the overall quality is spot on. That’s good to know regarding the volume, thanks!How does the welding look inside the pipes? My buddy has this fitted with a akra and itbs and the itbs are louder than the exhaust
Man maths [emoji23]I decided to keep her, it would have been such a waste to let her go.
It was MOT time on Monday and she passed (once I’d remembered to swap out my rear lights). However, on the way to the MOT the exhaust manifold flexi decided it wanted to fail lol. Pure Motorsport manifold is on the way. Proper man logic, spend more money on the money pit.
After looking at the logs on my ECU I’ve noticed that the fuel pressure is peaking over 6 bar when at full boost so I’m going to lower the static pressure to hopefully cure a weird misfire that has so far confused me.
Merry Christmas all!
They’ll only run with an aftermarket ECU unfortunately but in essence it is relatively simple. The original ECU can’t run these because of the trigger type needed and the undersized wiring.Sounds a simple mod
Have you had to have a tune to cope?
2006 Ultra Red Clio 197 - Trackday ready £4,500 | Clios For Sale | 0 | |
For Sale: Clio RS Gordini 200 | Clios For Sale | 0 | |
Clio 200 - Replacement Rear Calipers? | Suspension, Brakes & Steering | 1 | |
| A | RPM signal for shift lights - Clio Sport 197 (2008) | Clio 197 Area | 0 | |
RS200 Track Car | Projects/Progress Threads | 19 |
