Paul_D
Up early today with the aim of getting the front wheels off first and then continuing the battle with the brakes. I'm not a fan of jacking clio sports up. I really don't know why they have a front and rear jacking point as they are so stiff either one lifts one side clean off the floor! With an axle stand under one side the 200 is even worse than the 182 as it was blowing in the breeze with 3 wheels in the air! With the front on stands and the rear back on earth my trusty deadblow mallet was recruited for some gentle persuasion.
Yeah that's a bit browner than I expected! Not to worry it'll get sorted later, on with the bleeding:
Oh that nipple doesn't look very friendly does it? After attacking them with a wire brush and spraying with WD40 I started cleaning the disc face with some emery cloth while the WD did its best.
As expected the surface rust cleaned off easily and I ran a tap down to clean out the threads. At some point I'll have to remove the discs and clean all the blue paint off them but for now it's back to those scabby nipples.
No joy. As I don't have a flamethrower to hand I'll pass the job to my trusted mechanic and let him replace the nipples. After hammering off the other wheel that was in the same state.
I cleaned up the hub and face and gave every nut and bolt I could see a good dose of WD, there's a good probability I'll be back to replace more parts here in the not too distant future! Note to self: buy a blow torch.
At this point I considered taking the front bumper off to sort the peeling diamond out but I remembered the handbrake needed sorting so went to put the front wheels back on, but they were still tight as hell. The dremel was spun up with a scotchbrite wheel to shave off the powder coat in the spigot bore which had the desired effect and the wheels then slid on easily. A little coat of nail varnish to protect the ally and while that dried I cleaned up the rusty and blue wheel bolts.
The hand brake took a bit of fiddling around until I got it to a point where it actually locked the wheel. I'm not sure if the cable is the right one as it definitely doesn't have the same length of motion as the passenger side one does, and the cable is pretty rusty too. Its better than it was but mot worthy is another thing!
Back on the ground another job to tick off was replacing the windscreen wipers. I refitted the wiper linkage trim under the scuttle panel and the rubber seal after giving both a clean and copper slipped the splines before refitting the wiper arms. With more luck than judgement the wipers sit in the correct position and work perfectly. The battery clamp was in the door pocket so I re fitted that, I can see why it was left off as its a bit of a pain to get in even after removing the front fuse panel, but it's another job done for the mot.
Engine bay now all back together.
I did notice that the passenger side arch liner is broken, I suppose these are unique to the 200? It's definitely something that needs replacing. And all the mud needs cleaning out too!
Lastly I suspect the rear beam bushes weren't green from factory?
Can anyone shed any light on those for me?
To finish up in drove it 20 metres to park at the in-laws while they are away and didn't die. The brakes worked a lot better than before I bled the rears and when I went past an hour later it wasn't in their kitchen so the handbrake seems to be working too.
Tomorrow is a day on the 182, and then the twingo needs new brakes too. I'm supposed to be on holiday this week
