Well I finally had the chance to give the new set up a little try yesterday and it feels amazing. What a night and day difference to the old set up!
Makes me really want to get my B14's on! Going from cup shocks and H&R springs too, can't wait.
Out of curiosity what/how much did you have to cut? Just open up the hole by aset amount? Do you get a strengthening plate for underneath or do they assume the aluminium top will add in strength?I hope so, just need to pick up some paint to re-protect the metal following the cut in the strut top. Car is booked into get it all done on the 27th.
Do it once do it right if it was mine. Bit of a ball ache having to go back though!
Tbh I had considered cutting (and welding an extra plate for strength) my top mounts further in to effectively oval the hole and make it possible to add camber with slotting the bolt holes, see no reason why it wouldnt work nicely
Alignment time. Just waiting on the initial measurements and if the rear end is miles out I’ll buy some shims and come back for setup another time.
If it’s close enough side to side I’m going to go for a touch more front camber and toe out, don’t want to go too wild with it yet as it still gets more road use than track. But having the ability to get both sides equal should be good, the last alignment I got both front sides were different.
Doesn't it look great on that ramp amongst all that other drab stuff!!
If you need to adjust the front camber why not consider something like this?
https://www.powerflex.co.uk/product-details/Front+Arm+Front+Bush+Camber+Adjustable/11162.html
Despite having the early style I don't want to fit the coils since I'm really happy with the cup stock spring and shocks setup for the roads I usualy take.
To increase the camber when track time comes that will be what I'll try
It has nothing to do with kerb surfing... cornering forces act sideways and the bushes move in there housings, so it’s driving the car that moves them... so yes you probably will as lots of people have who don’t drive into kerbsI'm not planning on kerb surfing, so I shouldn't have major issues
Thanks for the feedback
For Sale: Clio 200 Race Car | Clios For Sale | 0 | ||
C | Early non cup 200 suspension advice | Suspension, Brakes & Steering | 4 | |
Somerset LY RS200 | Projects/Progress Threads | 12 | ||
R | Renault Clio RS 200 (with Cup Pack) in Deep Black - Track Build | Clios For Sale | 1 | |
200 - Chirp/whistle and occasional high idle | Clio 200 Area | 7 |
