With many thanks to Karl, Twingeekeo, I've got my mitts on a spare airbox to try a little experiment with.
PLAN
To increase cold airflow into the OEM airbox
WHY?
Because it heatsoaks badly, starving the engine of cold, dense air - which the ECU detects and retards the ignition, sapping you of power
HOW?
Part 1: Modify acoustic pipe to act as a 2nd cold air feed from the fog light. Plug vac pipe and remove acoustic flap housing.
Part 2: Heatshield pipework that runs across engine bay
Part 2: Remove restriction in 200 grille and lengthen intake to it.
RESULTS
I expect no more power, just consistent performance by ensuring cold, dense air is available.
Negative
Lose foglights.
PARTS
The aim is to do it as cheaply and as OEM as possible, so no moving batteries/header tanks etc.
Airbox. Use your existing, pick one up from a breakers or £65 for a complete new unit from the dealers.
Part 1: 1 metre of 55-57mm I/D neoprene anti-crush spung ducting (example) and appropriate sized venturi.
Part 2: Heat tape, such as DEI gold.
Part 3: Offcut of ducting and suitable rectangular inlet.
Part 1: Modifying inlet.
As you can see from the pictures, the inlet itself is a decent size, just points at the wrong angle. Fortunately, the way it is made (glued in) means it can be very easily changed.
Flat screwdriver in joint, hit it and voila! comes off. Dremel off excess and re-glue at desired angle.
To be continued with ducting 'how to'
Part 2: TBC
Part 3: TBC
Finished and test results: TBC
PLAN
WHY?
HOW?
RESULTS
Negative
Lose foglights.
PARTS
Part 2: TBC
Part 3: TBC
