Hi, yep it is a straight fit. Sorry not been on the forum much recently with the car being engine-less!
Although...my new engine is built and ready to be collected! I've taken my own advice this time and used a pretty stock bottom end (ARP rod bolts, ARP main studs) and mated this to the fancy head with 403's still, ITB's (to be built) and R3 exhaust, and ARP head studs (tbh the ARP mains and heads were left over otherwise I wouldn't have bothered).
This way if it fails again all I need to source is a stock spare engine and just swap the top ends over pretty much. Unless the belt goes and mangles the valves, in which case it's just new set of Supertechs; but regardless it'll be FAR cheaper to replace now [emoji4]
It should still do around 220bhp but obviously is never going to make up around the 240's like it always should have done if I got the right cams in it, because now it's inhibited by the valve/piston clearance. I guess it could make up to about 230bhp if the ITB setup really works and the lengths all work out etc, it'll sound mental anyway!
Oh and continuing my run of worst car luck ever.......my 'daily' has died too! A water leak through the sunroof, ran down into the fuse box and is currently fucked! Possibly picking up a 220T Trophy on the w/end to get mobile again, grown too used to a dual-clutch for daily duties![]()
Better late than never.
Anyway i have already fixed the FD in. It is not day and night but commuting around town is so much better now with more low end torque and i reckon the car should come stock with this ratio.
