Locking door mechanism
The door was locked closed , it was very difficult to open it, I needed to remove the seat open the door panel and break the mechanism.
I solved the problem, the answer to my question is that you can't use the lock from a 4-door clio because the cables that operate the mechanism are shorter.
This sounds like a very strange problem to have was the door not unlocking or hard to open, a door should always open from inside for safety but you do know the car has dead locks and if you triple locked the car it will not open from inside or if the battery is flat or at this time of year the door seal can be frozen and take quite a bit to pull open especially if it had just been washed. Well you will have to get a lock from a 3 door that is electric and deadlocking as there is one that just electric locks.
Clio 197 link Parts lookup website
My car doesent have this function with triple lock because has just one actuator în The mecanism. Îs tow type of mecanism with 4 pins or 6 pins. 6 pins means you have triple lock i guess.
