Hi,
I have a 06 plate 197 with 40.5k on the clock. It's running fine, apart from one thing and that is the button on the door handle that you press to lock the car.
I replaced the button battery in my key fob a couple of months ago and it worked fine, and as time as gone on I can't lock the car using the button on the handle I can only lock it by using the key fob.
The black sensor behind the door handle still works fine, it's just the button on either side, passenger and drivers doesn't lock the car.
Has anyone else had this problem and if so how did they go about it?
Look forward to your feedback.
Chris
Chris
