l33th3tr33
First lot of parcels have arrived, and while I was waiting for them I snapped/removed the diffuser! Both bolts snapped so I'm guessing it hasn't come off since the exhaust was fitted. It's zip tied on for now with some beefy zip ties so hopefully there's not enough heat in the area to melt them. Anyway.... the exhaust. No markings, so I don't have a clue what it is, maybe someone can help? I'm guessing eBay special.
Also, if you hadn't guessed already I do like my music. The problem is I don't want a sub rolling around in the boot, and I don't want an under seat sub, so I took the only other route for acceptable bass. Not the most ideal in terms of sound stage but it produces an acceptable amount of mid bass. Cue the 6x9's in the parcel shelf. Now I'm not one for cutting into the standard shelf and chucking the speakers in and calling it a day, one it looks crap, draws attention and labels you a chav, and two it's yet another reason to break into a car. I don't know if people still do that for a set of 6x9's but I'm not taking the chance.
The only way I am going to achieve this is with a stealth shelf. For the grand total of £20 for mdf and carpet here's the finished result.
It looks as oem as possible apart from being completely flat, but it won't rattle and once I've got some string and connectors for the boot lid it'll lift the same as the oem shelf.
Just waiting on my power cable to be delivered and then I'll have the fun task of getting that through the bulkhead along with wires through the door grommit. I'll change the heater resistor at the same time while the glovebox is out.
Sent from my iPhone using Tapatalk Pro
