Had my first ride on a kangaroo after work today in 1st gear, think it just wasn't warm enough or my clutch control wasn't on point, quite annoying when you put your foot down and you end up jerking about like a learner using a clutch for the first time
Im under warranty until Nov, maybe i should take it in to get this update you guys are on about...
Totally incorrect - once started the car should be driven, most wear occurs when cold and if the engine is idling at the same rev's it makes the situation worse, it will cause uneven wear.
The only time an engine should be left idling is if its a turbo thats just been ran hard, and thats to protect the bearings in the turbo.
Love this post as I am still in my first month of ownership and the jerkiness is worrying me sometimes, worry that I would harm the engine, gearbox or the clutch. As it is winter here and morning temp is around 10 most morning, this is what I started doing.
Start the car, slowly reverse out of garage, sit on driveway for about 20 sec, then start m journey to work. Try to go as light on the throttle as possible and short shifting (I find this is best to counter the jerking). About 1 to 1.5 km from home, the temp comes up and the car will begin to drive like a dream. But I do find the jerking is worse when you go down hill or try to get away quickly.
Does remapping help with this issue and is running higher octane better in countering this problem?
Thanks in advance
Built in safety feature to stop you caning it when its cold or something? Just never noticed it before till then lol
(I KNOW I SHOULDN'T DRIVE HARSH/FAST/HIGH REVS WHEN COLD)
| S | jerky 197 | Engine, Gearbox, Exhaust and Air Intake | 7 | |
| S | Jerky/kangarooing when cold? It might be worth checking this out! | Engine, Gearbox, Exhaust and Air Intake | 16 |
