Intermittent Starting Fault
Hi all,
First time posting. Got my 200 back in January and has always had a slightly rough idle from cold but had read that it was common so didn't take much notice.
Drove the car down to Spain and on the way back we pulled in for fuel, and after paying the car would not start at all. Had been driving for about 8 hours in 35C and then 2 hours in torrential rain. Was towed away by recovery and after a few days I asked them to try starting it, to which they said it wouldn't.
Got the car recovered back to the UK, and the recovery loader driver starts it up and drives it off the truck! But was running very very rough.
I knew by then that the Crank Position sensor was a common one to go, so cleaned it up and ordered a new one, and the car was running much better. This was about 4 days ago.
Went to get in it this morning and first the central locking wouldn't work, so changed the key battery to get that working (only changed the battery about 3 months ago) and then it wouldn't start. Exactly the same as before - cranking/turning over but not starting. The Crank sensor turned up a few hours later so I fitted it, thinking it would solve the problem but it didn't. Still the same issue.
I've checked all the relays in the box under the second air intake, all seem fine.
Popped the connector off the left side of the rail - no fuel.
Not getting any spark.
Main battery fuse (inside red + terminal cover) are fine.
So I'm thinking it could be the:
- Immobiliser? - But when I turn the ignition on, the red dash light flashes normally (once every 3 seconds).
- Fuel pump/relay? - I think I can hear it priming, but it's very feint. Could be hearing things.
- Camshaft Sensor - Not sure this would cause a no-start though, maybe just rough running?
Any help or suggestions would be great, I'm sure someone has had something similar before. I've read about blocked scuttles potentially causing electrical issues, but mine looked fine and I coudln't find any signs of this.
Thanks!
No fuel AND no spark is interesting. How does the immobiliser work on these Clios, does it cut fuel/spark?
That's what I've been told. But tried all sorts (it's push to start).
I find it really weird how it sat for a month in Spain and then started back up. Suggests something maybe dried out in that time?
Managed to get DTT4ALL working and managed to get these off it:
Assoc. DTC IDOBD P-CodeRenault DF CodeRenault Description (FR)English Translation
0x0100 (256)P0100DF056 / DF019Débitmètre / capteur de pressionAir flow / MAP sensor circuit
0x0225 (549)P0225DF008 / DF974Potentiomètre pédale, piste 1Accelerator pedal sensor track 1
0x0256 (598)P0605 / P0606 *DF002 / DF256Défaut mémoire données calculateurECU data memory fault
0x1201 (4609)–DFxxxDéfaut mémoire données calculateurECU data memory error
0x1206 (4614)–DFxxxDéfaut mémoire données calculateurECU data memory error
0x2993 (10643)P06xx (generic)–Circuit capteur court-circuit à la masseSensor circuit short to ground
0x2999 (10649)––Actionneur glissantActuator slipping
0x3006 (12294)––Défaut plausibilité signalSignal plausibility failure
0x3403 (13315)––Court-circuit / plage basseSensor circuit short to ground / low
0x3353 (13139)––Court-circuit / plage basseSensor circuit short to ground / low
0x0163 (355)P0163 / Uxxxx–Signal bus en dessous de la plageBus signal below allowable range
0x2692 (9874)P0605 / P0606 *DF002 / DFxxxDéfaut mémoire programme calculateurECU program memory failure
0x3803 (14339)P0562 / P0560DF047 / DFxxxTension alimentation calculateur trop basseECU supply voltage below threshold
0x42AF (17071)P0601 / P0606DF002 / DFxxxDéfaut interne calculateurInternal ECU failure
0x5441 (21569)–DFxxxCalculateur non configuréECU not configured / programming failure
0x1461 (5217)––Circuit capteur court-circuit / ouvertSensor circuit short to ground / open
0x2051 (8273)––Signal bloqué haut (capteur)Sensor signal stuck high
Anyone had any similar? I'm now leaning towards a wiring fault.
