Was driving last night and a car pulled out infront of me and I was doing 80mph odd, get on the brakes, a little bit of fade and the back end just sways from side to side under heavy braking, had me worried to say the least!
So... Went out today to have a play around slowing down for roundabouts leaving it late and the same again, even at 70mph, push the brakes hard and the back end twitches. Really feel a lack of control on the brakes at speed.
Anything I can do to solve the issue of the brake fade and twitchyness?
Had new pads fairly recently so unless they have glazed over I'm not sure what else is the problem. I'm fitting some KW V1's soon, will that make any difference?
I've also read on here about Dot 5.1 brake fluid and people using other pads, what are the advantages, will they make a dramatic difference, becuase if there's one thing I want perfect it's the brakes!!!
Hope you guys can help, thanks.
