Help Oil Everywhere!
Hello Guys!
Ive just got back from a short blast out and discovered quite a collection of oil around my spark plug area - quite shocked!! :worried: does anyone know what it might be?? pics attached
Yep rocker cover bolts and gasket mine did this after very hard track days
quite common this !
oil seeps from the 10mm rocker cover bolts - remove one at a time - clean and put a small amount of sealer under the bolt head - refit and nip down - should cure it :thumbsup:
Also, you've not topped any up or had a oil change recently? Very easy to spill some down there (speaking from experience on 197's and 172's lol!)
I dont think he was called Mr Watson! - since ive owned her ive had the full RS kit added - I went for this clio for the ultra low 10,000 on the clock and I loved the white alloys, you dont see many about. to be fair this is the first problem thats arose and for a four year old renault thats not bad going!!
ah i see its just with the front splitter and white wheels looks like james' old car 8)
