Does look that way. I only H&T on the road occasionally with just rev matching most of the time.
I found that the throttle sometimes need a bigger dab just to get the revs up as though it falls asleep if I'm coasting.
Left foot brake is also second nature in this car. Trying to perfect both feet overlapping whilst approaching a corner. Nearly there but need more tracktime.
I tried this today but was finding that my foot was just too skinny to bridge the gap between brake and accelerator.
What's the technique with overlapping the throttle and brake? Is this just left foot braking or is there more to it?
Imagine coming up to a sharp corner where you have to downshift from high speeds. You will H&T as normal, then after all your gearchanges are done your right foot would normally lift off the brakes and onto the throttle and left foot trasnfer onto the brakes. When overlapping both your feet would be on the brake pedal at the same time and thus you are never off the brakes.
I've never done that either...nor have I ever seen that done.
Tried this again tonight though I must say with a fudged gearbox lol.
The biggest problem I'm finding is either I'm not blipping the throttle hard enough or inconsistent braking when trying to move my foot to blip.
Sometimes find also letting the clutch out too soon and the car "jumping" when I do it. Least the gearbox is getting replaced next week so if I ruin this one I'll be ok lol.
Sounds like your foot is too far over the brake pedal.
If you position your foot so it's pretty much just the ball and your big toe on the rigt-most third of the brake pedal then you should be able to roll your ankle and get a decent amount of pressure onto the peddle with your three smallest toes and the bit of foot underneath them.
S | Wheeler race splitter | Body Work and Exterior Lights | 2 | |
Dead wheel bearing? | Suspension, Brakes & Steering | 7 | ||
Heel and toe | Clio General Chat | 15 | ||
B | Brake pedal goes too deep for comfortable heel and toe on track. | Suspension, Brakes & Steering | 5 | |
R | Heel & toe: tricks & info | Clio General Chat | 4 |
