GW 200 CUP (clubsport->racecar->v2)
Just read this start to finish again, had read most of it a few months back. Epic journey you have been on. Love it!
  • Love
Reactions: LiamP
The Clio sold, the new owner is looking to race in a few series this year (RoadSports / BRSCC) so will be good to see how he gets on.
Back in December I bought a Lotus Elise S1, I have been looking seriously for about 6 months but tbh I have dreamt of owning one since I was about 12 when seeing it in the back of one of Clarksons books.
It’s an ex Elise Trophy race car which has since been converted to road use, I messaged the owner by chance on insta after seeing it behind an F40 he also owned! Emotionally attached to the car but not driven for 2 years he allowed me to purchase with a view of getting it back on racing. It was a very competitive car in its day having won quite a few races and run by Rob Boston racing.
I made a very cheeky offer having not seen the car and he accepted, picked up a few weeks later whilst he was skiing. Completely blown away with how nice this car is, it looks like a show car and very hard to believe it ever raced.
Weighs around 700kg and about 150BHP at the wheels this should be about perfect for Roadsports / Club Enduro Class B (240/T with driver) No ABS, no TC, cable throttle, no brake booster and no power steering, I hope it drives like the saxo, raw, however I have only driven it off and onto a trailer so far..
It was converted about 3 years ago and then subsequently hasn’t been used for the last two so it needs a few things replaced and refreshed before it can get back on the track. To be perfectly honest if I had the space I think I would try and keep both and continue racing the clio but my hand was forced, I would like to continue this thread but understand if I lose a few readers..
That is beautiful wow. I am a sucker for a S1 Elise/Exige, they just look stunning. There was a Scandal Green Elise for sale back end of 2023 that I just missed out on.
Reactions: LiamP
The Clio has continued its form, now with an upgraded driver it scored a pole and 2 wins at Donington! I actually really enjoyed watching someone else racing it, maybe that is telling me something.
Back to the lotus and I have severely underestimated the amount of work required, what I thought would be a refresh has turned into more of a restoration. I think this is probably to be expected considering the amount of time off the road and the various changes made to allow it to be road legal.
I like to think of this list as reasons why I didn’t finish a track day / race had I just gone straight to the track.
  • Cambelt / water pump changed
  • Various seals changed
  • Oil leak isolated to oil filter housing, have removed and working on fitting oil temp/remove pressure sensor setup
  • Waiting on laminova oil cooler from HPE
  • 2 loose spark plugs
  • AN fitting welded to the cam cover to allow a simple catch can setup, just 5 helicoils required
  • Roll pin in the selector shaft removed and replaced
  • Starting to get dark thoughts about ecumaster ADU/PMU setup
  • Throttle pedal assembly missing various parts
  • Gaz monos serviced / sphericals and shafts replaced
  • At least one bearing needs replacing
  • FIA spec fuel tank (2.5k+) foam replaced and cleaned
  • No cat fitted, also concerned about noise so might get creative
  • ECU is incorrectly installed in the engine bay, wiring fixes also required
  • Both driveshaft nuts welded on (2hrs+ just to remove)
  • Clutch slave leaking / scoring
  • Latest find is a leak from the main seal, so gearbox is coming off
No idea where to start with this, since May it has been one step forward about 10 back every single damn week, highlights:
Laminova heat exchanger installed and plumbed in.
ECUMaster ADU / sensor install, got carried away but enjoyed this part.
Dampers rebuilt and every joint replaced.
Gear stick / linkages replaced / rebuilt / fixed.
So many dodgy fixes in the loom found and removed
New plugs and coils to fix a misfire when hot, two of the coils where completely wrong to the point I am not sure how the engine was even running.
It was at this point I released the valve seals had been leaking and the exhaust valves where in a very bad state so the head came off for new seals/guides and a clean up.
I then made a very stupid decision in seeing if I could get a head gasket to seal when the liners/deck surface looked like this.
It didn't work, immediate head gasket leak into the coolant when I tried a leaked down, pulled the engine and stripped it down.
Whoever originally build this engine liked RTV sealant as it was literally everywhere, including on the bottom of the liners. Liner 4 was a few weeks of rust away from a hole (there was even discolouration on the inside), I can only assume this sat with water in it for a while. Major thrust was a mirror finish so I have no idea how it was showing any compression.
To be continued...
We are now in August, brought the engine home and started cleaning, probably spent a week cleaning everything, the inside was just caked with oil.
Another week spent on the deck surface, this was first linished using a cutting stone to remove the coolant build up. The old liners had already been shimmed 5 thou however once the surface was cleaned I was able to remove these and get ~5 thou on the new Westwood liners. For some context the liner height is extremely important when it comes to the Rover K and is where a lot of the HG issues stem from.
img_2753-jpg.160545
The 160 pistons were within tolerance and tbh didn't want to have to upgrade, mainly because I don't want to have to increase the compression ratio you get with forged. Simply cleaned, measured, new rings, gapped, mahle motorsport bearings and ARP bolts.
Crank was lightly cleaned/polished and I then found out the reason why my main seal had continued to leak, an almost perfect strip of RTV/glue? acting like an oil extraction device.
I then tried to torque the bearing ladder, bolt 1 and 10 stripped the threads at 5Nm, after sulking for a week and racing at the 2CV 24Hr race I came back to helicoil all 10 which worked successfully.
Built the short block up whilst replacing everything that would help reliability such as the oil ladder, oil pump, any seals, bolts etc. Fed up of this taking so long I booked in at Emerald giving me about a week and a half to finish..
Another day or so of hard work and the car was back on 4 wheels for the first time since March, the engine started although I only ran it for about 3 minutes to confirm no leaks/oil pressure/bleed as I didn't want to glaze the new liners.
Turned up to Emerald on Monday extremely nervous about what pain the car was about to put me through but it was obvious I was in safe hands with Dave. Spent almost the entire day with me to get the car mapped perfectly from idle to full power, strongly recommend a visit if you have an Emerald.
The engine ended up making 180.6 BHP / 146.4 lbf.ft I was hoping for >170 so 180 is mega, any more and I would have issues meeting the BHP/T I want to race in.
This was at 7k, so likely a few more available if I wanted to rev higher but the torque curve is almost dead flat with the 285H cams and I like the idea of having more reliability considering this is going to spend most of its life high up the rev range.
Shakedown next..
