Back to NADUK at the start of last week to install recently purchased 100Nm springs for the rear, mega easy to change as you can get away with sliding the spring from the bottom so only one bolt to undo. Rear shims then added to reduce the toe back to 8 degrees both sides and the camber upped on the offside, I am now at the max camber at the front with the AST mounts:
Had the corner weighting checked and the car is currently 1139kg (dry) which I am happy about as its now 20kg lighter but with a half cage. Ideally I get this as close to 1100 but might be tricky with the majority of the interior staying.
Then Goodwood on Friday, weather was ideal with 21 degrees, blue Skys and a full tank.. First time back with the spacers off since having the geo done combined with the spring change the car was very different to drive! I could actually get some rotation of the rear and it felt great.
The morning was very busy so had some time in the queue to check things, had a quick look under the bonnet and noticed my alt belt was in a really bad way (third time) Not wanting to risk things I got out the queue and started phoning around locally to see if I could get a spare, luckily managed to find one (7PK 1135 if anyone is ever after a non Renault belt) so a quick 1hr round trip to Petersfield and super quick change in the pits I was back out after lunch. I have since had a proper look at what is causing this and it seems my tensioner is either faulty or misaligned causing extra tension in the belt, now changed which is hopefully going to fix things.
Overall the car was great and the quickest I have ever been around Goodwood, I think a 1:30 is now possible in this car with the right driver. Quick video of me pushing things a bit too far and taking out a sign BTTC style, wish I had a rear camera (sorry if you have already seen it on fb)
Will soon be joining the cool kids as I have picked up some lightly used MRF’s for £50 a tyre from a civic cup racer so will be interesting to see how they compare to AR1.
Todo list gets longer and longer every day but currently:
- Strip out rear wiring loom / tidy up
- Change front brakes, ds1.11 have only just started to go now they are at about 3mm (9/10 trackdays) so will be replacing
- Black series gearbox and engine mounts (will probably regret this)
- Oil change (gearbox and engine)
- Resist purchase of gripper..
Gone mental and booked lots of trackdays:
- Brands Hatch 27th October
- Snetterton 8th November
- Goodwood 29th November
- Goodwood 17th December
