So where are you putting the battery then Tamas? There will be some noticeable weight loss from the front when you take into consideration AC and battery Don't try to drive your car in the Alps on a rainy summer day though haha
Looks very nice Tamas! Curious for the result!
Why did you choose too place the expansion thank on the right side? If I remember right it's normally placed on the left?
I see the way I did it as been taken up. Nice to know great minds think alike! Are you going to move your air temp sensor away from the inlet manifold onto the air inlet of the filter. toyed with the idea of doing this, but I think Ill do this when I come to re mapp the beast in the spring, thats after fitting the R3 exhaust manifold. See what differing results bring.
Lol, that's my picture/part.[MENTION=30849]fre23[/MENTION], because I will have a hybrid solution: R3 Acces airbox but R3 Maxi front piece, so the fresh cold air will come from where the header tank is sitting. The rally garage decided to move it to the left, not too close to the hot engine and the mounting point are better on hte left side.
I already removed the washing liquid tank, as its useless, and could save min 5.5kg - think about when its fulfilled with liquid.
Untitled by Tamás Flatsker, on Flickr
wow @krash67, was not aware you have done it in the same way!
Looks like I have to change the top engine bearer/bracket and I can see yours is not OEM Renaultsport, may I ask why have you opted for this?
[MENTION=41063]Pav[/MENTION] No problem - looks like it is. I also found this over on PH (scroll right to bottom of first page) - http://www.pistonheads.com/gassing/topic.asp?t=1528415thanks @CallorFold..looks like it may be it..well spotted
I think I know what you mean, but its the original mounts but fitted with power flex bushes.
G | Ktec-Racing induction kit | Clio 197 Area | 1 | |
Racing Blue Clio towards Newbury. | Spotted | 0 | ||
Mike's racing blue 197 | Projects/Progress Threads | 109 | ||
BAF Motorsport K-brace vs Ultra Racing | Interior and Audio | 6 |
