I have been looking at AST's.
had ast's on scooby just sold. But loved the bilsteins on the RS so think going try them
I'm sure we can do something.![]()
99% sure these will be like standard set up. They are on the mk2. So like KW V1
Let me know what you can do mate. Looks like Chris will have a set too?
100% up for this
so thats X3, dont let us down guys
best price ;-) ;-)
You'd expect a company of bilsten to produce a decent suspenion kit to be fair.
I can do a group buy price of £730 delivered which is very good value as our online price is well in under retail. Won't be making much at all tbh but it'll be good to get some decent feedback.
I'll post a discount code later on. Not looking for a minimum number on this.
Get it done cash waiting ;-)
Fantastic. Will more than likely order this week.
These Bilsteins - if it is a seperate spring, look to be soft then at the rear. The motion ratio of seperate dampers to springs means you need to go for a higher spring rate so you get the right wheel rate.
These are the rates for the 200 below, in each case the rear is stiffer:
200 Standard Springs
Front: 144.5 lb/in 25.3 n/mm
Rear: 215 lb/in 37.6 n/mm
200 Cup Springs
Front: 224.8 lb/in 39.4 n/mm
Rear: 260 lb/in 45.5 n/mm
Eibach
Front: 27-45N/mm
Rear: 32-54N/mm
HR
Front: 37N/mm
Rear: 53N/mm
The rear being stiffer is because the motion ratio is not 1:1 like it is at the front. It's probably something like 1.5:1, so if you divide the rear rates by 1.5, as I understand it that is indicitive to the wheel rate. So the rear is effectilvey softer but the higher spring rate will balance it somewhat.
Now if you look at AST where the rear is a proper coilover then it's 1:1. The rates on the track setup are 100Nm front and 110Nm rear. - This is a genuinley stiffer rear - that's because it is what you want on a fwd track car.
So going back to the Bilsteins, if they are standard location, I would expect to see a higher spring rate on the rear??? Otherwise with the motion ratio factor this setup is actually making the rear software in comparison to the front vs OEM.....
I FINALLY BOUGHT MY FIRST CAR ! | New Members | 5 | |
Not so New member finally in a Clio | New Members | 0 | |
Finally got a Clio RS!! | New Members | 0 | |
finally got a few jobs done, now got a creak | Clio 197 Area | 2 | |
Restoring Clio Cup 200 Finally! | Projects/Progress Threads | 9 |
