jakehewitt
North East Rep
So went to trax yesterday, everything fine with her. Got some free injector cleaner, put that in, went on track and everything ran fine, not a hiccup. On the way home pulled off at Leicester services and filled up, then around about 20 miles past there there was a pop (I think this may have been the exhaust as it makes the same noise when I come off throttle) and car goes into limp mode, injector fault on the dash and sounds like it's only running on 2 cylinders.
Pull over, turn engine off, restart and everythings fine again. Go back on my way 2 miles on happens again. Turn off the sprintbooster, ran obd and found the fault code cleared it, left it to idle for a bit and headed back. Was fine for another 20 miles did it again, this happened over and over sometimes I would get 5 miles sometimes a bit further until about 40 miles away from my house where there wasn't another problem. I did try and recreate the problem closer to my house but couldn't.
Anyone had this? I haven't a clue what it could be, and I didn't rag her that hard round the track compared to what I'd do at hartside or the moors :/
